ESPixel Stick & ESPixel Pops
Version V2
Version V2
The genesis of the pixel stick controllers started with designes by Bill Porter. You can read about this at Bills website found at: The mind of Bill Porter The ESPixel Pops is the most basic of the Pixel Stick designs. It is a fully through hole PCB with no smd(surface mount) components. Therefore, it is easily built by most anyone with basic soldering skills. This variation was created by Pops Jones (ukewarrior) in order to create a form factor that would fit inside a 1" thin wall PVC tube.
small
small
4. The board is small enough to fit inside a 1" thinwall PCB pipe with the board measuring only 24.18x33.32 mm
Order your own boards
Here is a picture of a completed ESPixel Pops: (The fuse cover has been removed) Updated picture to be added....
Wiring The ESPixel Pops
Controller Output Pinout
Pin Number Connection
1 +5v DC Power
2 Channel 1 Signal
3 reserved
4 Channel 2 Signal
5 reserved
6 Channel 3 Signal
7 Ground
8 Channel 4 Signal
Version G2
Version G2
