Power Pops Fanout - 1 Input with 4 Outputs
![Version V2](/wiki/images/9/95/Production_board_picture.jpg)
The Power Pops Fanout 1 to 4 version is a simple DC power splitter.
This board is designed to take one input DC power feed and split it into 4 outputs.
Each output on the board has an mini-automobile style fuse that is rated up to 5 amps.
Additionally, each output has a LED status indicator to show if power is flowing to that specific output; therefore showing that power is present and that the fuse is good.
There is a switch on the board that activates the function of all the status LEDs thereby allowing the user to turn off the LEDs unless needed. This switch does NOT turn off the power feed. It has no affect on the flow of power except to the LED indicators.
![small](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
The Power Pops Fanout board has these main features
1. Suppoorts the splitting of up to 20 amps of DC power into 4 individual power outlets of up to 5 amps each.
2. Is a DIY board using all through hole components for easy DIY soldering.
3. Was designed to support up to 20 amps of DC power at a maximum of 28 Volts.
4. Input & output power can be soldered directly to the board or mounted via 9.3mm(input) and 5mm(outputs) terminal blocks.
5. Each power output is individually fused with a status LED indicating the state of power and the fuse.
Order your own boards
USE the Power Pops Fanout board at Your Own Risk !
The Power Pops Fanout board has NO warranty expressed or implied
- One Mosfet. This must be: 2N7000, which has a T0-92-3 style package
- A five pin screw terminal header. 5 positions total. This connection should have 3.81 spacing of the mounting pins.
![Version V2](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
Wiring The Power Pops Fanout board
You can either solder on a terminal block or directly solder your wires to the board, or do a mix ! The Terminal block has 3.81mm hole spacing. (The more common 5mm terminal blocks would have made the board too wide)
