ESPixel Stick & ESPixel Pops
Click Here:
Pixel Pops & Tiny
Order your own boards
This can be done very inexpensively with a fuse holder and fuse. These are available for a total of 32 cents from Tayda Electronics.
- One Mosfet. This must be: 2N7000 or ZVN3306A, which has a T0-92-3 style package
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
The board has a place for a second voltage regulator. This is to accommodate 5V pixels even if your input power is 12V.
The part laveled: IC1 is NOT installed if you are running 5V Pixel strings AND you must place a jumper in its place as noted on the board.
Wiring The ESPixel Pops
A Key Point Regarding Power
One thing you have to decide is if you will power your pixels through the ESPixel Stick or directly to the Pixel string.
Programming the ESP-01 Module
Under Construction
