Ren-T Assembly Instructions
Revision as of 02:54, 22 February 2008 by Ravinglunatic (talk | contribs)
Configurations
This board can be assembled and used in various ways. It can be used simply to generate a zero-crossing signal for the Renard8, Renard64 and Ren-C boards (and optionally for some of the other boards), power for the Renard8 board, and/or convert RS232 to RS485 for use with any of the Renard coop boards (including Ren-C). It can also be built using a number of different transformers (depending on which board is used, and which transformers the builder has on hand).
Selecting a Transformer
There are several different possible choices of a transformer. The most basic considerations are the input voltage, the output voltage and output current ratings of the transformer. In this discussion, primary will refer to the transformers input winding(s) (that are connected to the AC power line), and secondary refers to the output winding(s) of the transformer.
The input voltage of the transformer must be the same as the AC line voltage available in your locale. You cannot use a 120VAC transformer in a location with 240 VAC power, nor can you use a 240VAC transformer if your local power is 120VAC. There are some transformers with dual primaries that can be wired up to accept either 120 or 240 VAC, but discussion of how to use these is beyond the scope of this page.
The preferred design uses a center-tapped transformer. This is a transformer which has a single output winding with three connections (one at either end of the winding, and one in the exact middle), in which the middle connection (the center-tap) is to be used. One disadvantage of this circuit is that the iron and copper in the transformer is only used with 50% effectiveness because at any point in time only half of the transformer is supplying current.
The transformer output voltage should be either 12.6VAC or 16 VAC, and the output wires from the transformer should be connected as shown here.
The effective schematic (taking into account the parts which are actually installed) is here:
The waveform across the output of the transformer (pins 5,8) is a sine wave with amplitude 1.41*Vtrans when fully loaded (where Vtrans would be the 12.6V or 16V rated value of the transformer). The amplitude will be somewhat higher if there is no load on the transformer or just a minimal load. The voltage between the transformer center-tap and either of the other two legs is 1/2 of this value.
The output of the rectifier circuit (VOUT+ - VOUT-) is a rectified sinewave, as shown below. The amplitude of the output waveform is (1.41*Vtrans/2 - Vf), where Vf is the forward voltage of the diodes (about 0.7V for regular diodes, 0.4V for Schottky diodes).
Case 1
Connecting PC to first controller without converting to RS485
  • D1, D2, D3, R1, R2, P1, JR1, J1 (shunt), J2 (shunt)
Case 2
Connecting one Controller to the next (RS485 pass-through)
  • D1, D2, D3, R1, R2, JR1, JR2 (omit shunts)
Case 3
Connecting PC to first controller, converting to RS485 in the process
  • D1, D2, D3, D4, D7, R1, R2, P1, JR1, U1, U2, U3, C1, C2 (omit shunts)
Mouser part#'s listed.
  • U3 ~ 1 - 595-UA78L05ACLPRE3 - Standard 5V, 100mA Fixed Pos Voltage Regulator
  • U2 ~ 1 - 837-ISL81487EIP - RS-485/422 Interface ICs 5V TXRX ESD
  • U1 ~ 1 - 595-SN75C189AN - RS-232 Interface ICs Quad Low Pwr
  • C1 ~ 1 - 140-XRL16V10-RC - Radial Electrolytic Capacitors 16V 10uF 20%
  • C2 ~ 1 - 140-XRL16V470-RC - Radial Electrolytic Capacitors 10V 470uF 20%
  • D1, D2, D4, D7 ~ 4* - 625-1N5819-E3 - Schottky Rectifiers Vr/40V Io/1A
  • D3 ~ 1 - 604-WP7104GT ***(or)*** 604-WP7104IT - LED > GT = Green ~ IT = Red
  • R1 ~ 1 - 291-1K-RC - 1/4W 5% Carbon Film Resistors 1Kohms 0.05
  • R2 ~ 1 - 291-750-RC - 1/4W 5% Carbon Film Resistors 750ohms 0.05 (LED resistor)
  • J1, J2 ~ 2 - 538-22-03-2021 - .100 K.K. Connectors VERT PCB HDR 2P TIN PLATING
  • 2 - 649-65474-002LF - Bergcon Connectors SHUNT TIN
  • P1 ~ 1 - 152-3409 - D-Sub Connectors 9C R/A PCB RECPT
  • JR1, JR2 ~ 2 - 571-5520251-4 - Modular Jacks 8/8 SIDE ENTRY
Optional Parts
  • 1 - 693-CMF1.1111.12 - Power Entry Modules 2.5A C8 INLET PCB MT (requires the AC cord below, or an older style 'laptop' power cord. Check the data sheet for a picture.)
  • 1- 173-21114-E - AC Power Cord 10' 2W 18AWG BK
  • 1 - 571-3902613 - IC Sockets 14P ECONOMY TIN
  • 1 - 571-3902612 - IC Sockets 8P ECONOMY TIN
TRANFORMER CHOICES
41PG300 - 12.6CT .3A
  • The transformers listed are not the only ones that can be used. They are what was used during the design and testing and are direct fits for the pads of the PCB.
History
2007/09/03 Removed references to non-center-tapped transformer, as they do not always reliably provide a good zero-crossing signal.
Ren-T PCB Assembly Instructions
