Serial, RS232
Revision as of 20:46, 17 March 2009 by Wvengineer (talk | contribs)
Voltages
RS232 voltage values
LevelTransmitter capable (V)Receiver capable (V)
Space state (0)+5 Vdc up to +15 Vdc+3 Vdc up to +25 Vdc
Mark state (1)-5 Vdc up to -15 Vdc-3 Vdc up to -25 Vdc
Undefined--3Vdc up to +3Vdc
Pinouts
View - looking into Male connectorView - looking into Female connector
Pin No.NameDirNotes/Description
1DCDINData Carrier Detect. Raised by DCE when modem synchronized.
2RDINReceive Data (a.k.a RxD, Rx). Arriving data from DCE.
3TDOUTTransmit Data (a.k.a TxD, Tx). Sending data from DTE.
4DTROUTData Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE.
5SGND-Ground
6DSRINData Set Ready. Raised by DCE to indicate ready.
7RTSOUTRequest To Send. Raised by DTE when it wishes to send. Expects CTS from DCE.
8CTSINClear To Send. Raised by DCE in response to RTS from DTE.
9RIINRing Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer.
Achievable distances
The maximum distance that RS323 can go varies depending on Bit Rate and also the capacitance of the wire itself. Texas Instruments states that RS 232 maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Depending on the cable such as Category 5 Twisted pair the maximum achievable distance at 19200 is 157 feet.
here is a quick chart showing theoretical limits as various data rates for RS232 cable length according to Texas Instruments
Baud rate Maximum cable length (ft)
1920050
9600500
48001000
24003000
Interfacing to Microcontrollers
In order for RS232 to communicate with a Microcontroller such as a Pic16f88 or Atmel, level conversion must first be done because of the voltage levels on TTL is 5 Vdc max.
Devices such as a MAX232 will make the necessary voltage conversion possible for communication.
External Links
