Troubleshooting Guide The Renard SS24
Click here for the previous version done by oldcgr.
- This page is intended to help identify/isolate some of the common problems individuals encounter when building/operating the Renard SS24 controller board.
Basic Troubleshooting Info
Verify Setup
- Verify that the Renard SS24 is assembled correctly as compared to the Renard SS24 Controller Assembly Instructions wiki.
- Verify that you have power/control cables connected correctly as compared to the Renard SS24 Controller wiki.
- Verify that you have the Vixen plug-in settings correct as compared to the Renard SS24 Controller wiki.
Most Common Problems
- Bad data cable coming from the computer. Many individuals assume that all serial cables are identical, but that is far from the truth. Just because a cable has the correct DE9 connectors on each end doesn’t mean that the wires inside are going to the correct pins for Renard operation. It is always best to physically check the pin continuity to verify that the cable will work for Renard operation. Make sure that your interconnect cable is wired according to the Renard SS24 Controller wiki.
- Incorrect Vixen Settings. It cannot be emphasized enough, the Renard boards will not work correctly if Vixen is not setup correctly. Verify that you have the Vixen plug-in settings correct as compared to the Renard SS24 Controller wiki.
Troubleshooting the Renard SS24 Controller
Troubleshooting Flow
Troubleshooting Steps
- Verify that you have the power/control cables connected correctly as compared to the Renard SS24 Controller wiki.
- For the following steps, the PICs (U6 thru U8) need to be programmed with the Renard Operational Firmware.
- Turn ON AC power
- PWR LED should be lit
- Run a Vixen sequence
- If they do, go to step 15
- Turn OFF AC power
- Swap PIC chips U7 and U6
- Turn ON AC power
- If they don't, reprogram or replace PIC chip U6 and retest
- Turn OFF AC power
- Swap PIC chips U8 and U6
- Turn ON AC power
- If they don’t, replace PIC chip U6 and retest
Symptom(s):
- PWR LED not lit
- IC Chips hot to the touch
Possible Problem(s):
- No input voltage present
- Transformer bad
- Voltage Regulator bad
- LED installed backwards
- Blown fuse
- Remove power from Renard SS24
- Disconnect all cables.
- If installed, remove all 30 IC chips from their sockets (U2, U4 thru U8, and M1 thru M24).
- Turn ON AC power.
- Did the fuse blow?
- If it did, go to step 17
- If incorrect, go to step 13
- Did the PWR LED light?
- If it did, go to step 21
- Measure AC voltage between  top side of F1 and any N terminal.
- Measure AC voltage between  bottom side of F1 and any N terminal.
- Turn OFF AC power
- Remove F1
- Turn ON AC power
- Recheck AC voltage between  bottom side of F1 and any N terminal.
- Bad/shorted triac
- Turn OFF AC power
- Install one of the IC chips (U2, U4 thru U8, and M1 thru M24) into its respective socket.
- Turn ON AC power
Symptom(s):
- HB and ZC LED do not flash
- FE and/or OE LEDs light
- Oscillator bad
- Zero Cross signal bad
- Vixen settings incorrect
- PIC bad
- Turn OFF AC power
- Remove PIC chip U6
- Turn ON AC power
- The  Beta Renard Diagnostic Firmware should perform the following channel test:
 - Replace U2
- Check the values of R1 & R2
 REMINDER:
 NOTE:
- SD LED will be ON whenever Vixen sends data to the Renard SS24.  The FE and OE LEDs should remain OFF.
- Replace U5
- Turn OFF AC power
- Turn ON AC power
- HB LED should light
- ZC LED should light
- SD LED should light
- FE LED should light
- OE LED should light
- b. Remove shunt from JP3
- d. Install shunt on JP3
- If incorrect, replace RN1
Symptom(s):
- Bad triac
- Bad opto
- Bad/missed solder joints
- Turn OFF AC power
- Are channels 13 thru 24 bad?  If they are,
- Check the right side fuse
- If not, go to step 21
- Turn ON AC power
- Test lights should be OFF
- Turn OFF AC power
- Install PIC chip U6
- Turn OFF AC power
- Turn OFF AC power
- Turn ON AC power
 SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
- If not, go to step 37
- Remove PIC chip U7
- Turn ON AC power
- Turn OFF AC power
- Install PIC chip U7
- Turn OFF AC power
- Turn OFF AC power
- Turn ON AC power
 SAFETY NOTICE:
- Bad triac
- Remove PIC chip U8
- Turn ON AC power
- Turn OFF AC power
- Install PIC chip U8
- Turn OFF AC power
- Turn OFF AC power
- Turn ON AC power
 SAFETY NOTICE:
- Bad triac
- Turn OFF AC power
- Turn ON AC power
- Is the test light still ON?
