16 Channel Renard with SSR Assembly Instructions
- Assembly Time: 2 hours
- Skill Level: Medium
Disclaimer
Use of this material is undertaken at the users own risk. We assume no responsibility for any consequences you encounter by using the information here.
Tools
- Bench Soldering Iron
- Silver Solder
- Flat cut dykes
- Desoldering bulb
Build Steps
Install Item | Qty | Mouser P/N | Location | Notes |
1. IC sockets 6 pin | 17 | 571-3902611 | U3-U19 | Make sure they are oriented the same way as the silk screen image. U19 is oriented opposite of the others |
2. IC Sockets 8 Pin | 2 | 575-193308 | U20 & U21 | |
3. IC Sockets 14 Pin | 2 | 575-199314 | U1 & U2 | |
4. Bossman Fuse Holder | 4 | 504-1a3399-10 | H1 & H2 pads | Make Sure the notch on the fuse holder are oriented so one is on the top and the other on the bottom to properly hold the fuse. |
5. Euro Sytle Terminal Blocks | 11 | 538-398890-0302 | Lower Edge of Board | |
6. 15Kohm REsistors | 2 | 71-ccf60-15k-e3 | R17 & R18 | |
7. 178 ohm resistor | 16 | 273-178-rc | R1 - R16 | Orient the color all the same way for easy of troubleshooting later |
8. 10pin 680ohm bus resistor | 2 | 266-680 | above U7 & U15 | |
Numbered Photo
[1] File:Http://www.christmasinshirley.com/forum/album pic.php?pic id=49 | ||||
6. | 1 | 11-11 | spot1 | |
Still Entering Give me so time to finish before you edit this please
