Beginners Setup Guide Renard Boards with External SSR
This page was created to help out the new users who aren't fully confident that they have built their Renard board correctly. These steps are designed to allow the user to test/verify most components in a manner that should help to eliminate the possibility of damaging any of the components during initial testing.
The following procedures may appear to be tedious and time consuming but they are here for the individuals who are not confident in their soldering skills. By following these steps, the individual will be able to test out individual components and signal paths to verify that everything is working properly with minimal damage to components and rework.
The following procedures require the individual to be familiar with the operation of a digital multimeter (or voltmeter/ohmmeter if you prefer). If you currently do not know how to measure resistance or how to measure voltage, please take some time now an learn these basic skills before attempting these procedures. This website provides some basic information on using multimeters.
Renard Basic Setup Steps
- Ensure all power is OFF
- Remove all cables
- If installed, remove all the removable IC chips. For this example, the REN64 will be used. For other boards, the items will be similar but the chip number may be different. (U2, U4 thru U8, and M1 thru M24). The REN64XC chips to be removed are: U3, U4, U5, U7-U14.
- Perform a complete and thorough inspection of the underside of the PCB.
- Check all the solder pads for clean solder joints, no bridging between adjacent pads and that all pads did get soldered.
- Make sure the board surface is clean and free from any debris and flux residue.
- Connect a 6.3VAC power supply to Tab1/Tab2. This requires understanding how to wire up the transformer.
- Turn ON AC power
- Measure DC voltage at the +5 test point (below U1).
- It should be 5.0 (+/- .1) VDC
- If incorrect , then go to the Renard SS24 Troubleshooting Guide
- Power LED should be lit.
- If it didn’t , then go to the Renard SS24 Troubleshooting Guide
- Momentarily connect a jumper (small piece of wire) between U7 IC socket pin 13 and pin 14
- Channel X LED should light-->This is the HB LED. Once again, the chip numbering is specific to the REN64XC. Some Renard boards have specific LEDs for the HB or "Heart Beat" Function.
- Momentarily connect a jumper between U7 IC socket pin 10 and pin 14
- Channel X LED should light -->This is the ZC or "Zero Crossing" LED
- Momentarily connect a jumper between U7 IC socket pin 9 and pin 14
- Channel X LED should light -->This is the SD or "Data" LED.
- Momentarily connect a jumper between U7 IC socket pin 8 and pin 14
- Channel X LED should light -->This is the FE or "Framing Error" LED.
- Momentarily connect a jumper between U7 IC socket pin 7 and pin 14
- Channel X LED should light -->This is the OE or "Overun" LED.
- If any of the LEDs in steps 11 thru 15 did not light, then go to the Renard SS24 Troubleshooting Guide
- Turn OFF AC power
- Install a SSR like the SSRez into Jxx.
- Attach some test lights to the SSR terminal block for Channel 1.
- Turn ON AC power
- The power LED on the SSR should be on.
- Test lights should be OFF
- Momentarily connect a jumper (small piece of wire) between U7 IC socket pin 3 and pin 14
- Test lights should come ON when the jumper is connected
- If either step 23 or step 24 failed, then go to the Renard SS24 Troubleshooting Guide
- Repeat steps 18 thru 25 using the information in the following table:
Optoisolator Test Lights at
Terminal BlockConnect jumper between M2 [N Ch2] M3 [N Ch3] M4 [N Ch4] M5 [N Ch5] M6 [N Ch6] M7 [N Ch7] M8 [N Ch8]
- Turn OFF AC power
- Connect an AC power cable to the right side 120V terminal block. The 120V neutral line (wide blade on a polarized plug) goes to the N terminal and the 120V hot line goes to the 120V terminal. This connection can be either a separate power cord or it can just be a jumper from the left side 120V terminal block.
- If not installed already, install an appropriate value fuse in the right side fuse holder.
- The fuse needs to be rated to handle the load of the lights that will be connected to channels 9 thru 16 but not greater than 15 amps.
- Make sure the AC power cable going to the left side 120V terminal block is still securely attached.
- Turn OFF AC power
- Install optoisolator M9 (PN# 859-MOC3023)
- Attach some test lights to the [N Ch9] terminal block
- Turn ON AC power
- If either step 35 or step 36 failed, then go to the Renard SS24 Troubleshooting Guide
- Repeat steps 31 thru 37 using the information in the following table:
Terminal BlockConnect jumper between M10 [N Ch10] M11 [N Ch11] M12 [N Ch12] M13 [N Ch13] M14 [N Ch14] M15 [N Ch15] M16 [N Ch16]
- Turn OFF AC power
- Install optoisolator M17 (PN# 859-MOC3023)
- Attach some test lights to the [N Ch17] terminal block
- Turn ON AC power
- Momentarily connect a jumper (small piece of wire) between U8 IC socket pin 3 and pin 14
- If either step 43 or step 44 failed, then go to the Renard SS24 Troubleshooting Guide
- Repeat steps 39 thru 45 using the information in the following table:
Terminal BlockConnect jumper between M18 [N Ch18] M19 [N Ch19] M20 [N Ch20] M21 [N Ch21] M22 [N Ch22] M23 [N Ch23] M24 [N Ch24]
- Turn OFF AC power
- Place a shunt on JP2
- Install optocoupler U2 (PN# 782-H11AA1).
- Install two RS232/RS485 Interface ICs U4 & U5 (PN# 511-ST485BN).
- If you have a PIC programmed with the Renard Diagnostic Firmware continue with step 31.
- If you only have a PIC programmed with the Renard Operational Firmware then go to step 47.
- Install PIC microcontroller U6 (PN# 579-PIC16F688-I/P) programmed with the Renard Diagnostic Firmware.
- Place a shunt (jumper) on JP3.
- Turn ON AC power
NOTE:
The following step only applies if you are using the Beta Renard Diagnostic Firmware.
If you are using the proven/existing Renard Diagnostic Firmware just skip this step.
- The Renard Diagnostic Firmware should perform the following channel test:
- If either step 55 or step 56 failed, then go to the Renard SS24 Troubleshooting Guide
- Turn OFF AC power
- Connect a data cable to the computer running Vixen to either J2 or JDP1 on the Renard SS24.
- If receiving RS232 data from the computer place a shunt on JP1
- Turn ON AC power
- Wait for the diagnostics routine in step 55 to complete
REMINDER:
The Renard SS24 Controller Board wiki page. The only difference would be to
set the baud rate to 19200 for the non-beta Renard Diagnostic Firmware.
- Run a Vixen sequence
NOTE:
- Turn OFF AC power
- Remove U6
- To verify other functional PICs, repeat steps 51 thru 66 with two new PICs
- Install PIC microcontrollers U6, U7 & U8 (PN# 579-PIC16F688-I/P) programmed with the Renard Operational Firmware.
- Turn ON AC power
REMINDER:
- If the outputs do not respond correctly, then go to the Renard SS24 Troubleshooting Guide
