Ren48LSDv3c
What is the Ren48LSD?
The strips require up to 360mA per output (18 LEDs x 20mA) so I used an NPN bipolar transistor to drive them. The transistors support up to 600mA so there's plenty of headroom left. The transistors are fairly cheap so it makes for a simple, inexpensive solution. The controller design used the Ren24SS as a base, using the same PIC, clocking and serial interface configuration but expanded to 6 PICs to support 48 channels or driving up to 12 strips per board. Because of this, the controller supports standard Renard protocol FW using RS-232/485 as well as the DMX version. The board requires either a 5vdc well regulated supply or a good 9- 12vdc supply. The input supply also drives the LED strips.
Ren48LSD Parts
Mouser BOM | ||
579-PIC16F688-I/P | Microcontrollers (MCU) 7KB 256 RAM 12 I/O | 6 |
571-1-390261-3 | IC & Component Sockets 14P ECONOMY TIN | 6 |
511-ST485BN | Buffers & Line Drivers Hi-Spd Lo Pwr Trans | 2 |
571-1-390261-2 | IC & Component Sockets 8P ECONOMY TIN | 2 |
520-TCH1843-X | ECS-2100AX-18.432MHZ | 1 |
863-MPS2222AG | Bipolar Transistors 600mA 75V NPN | 48 |
78-1N5239B | Zener Diodes 9.1 Volt 0.5 Watt | 1 |
78-1N5229B | Zener Diodes 4.3 Volt 0.5 Watt | 1 |
863-1N5819G | Schottky (Diodes & Rectifiers) 1A 40V | 2 |
863-LM2575TV-5G | Switching Converters, Regulators & Controllers 5V 1A PWR SW REG | 1 |
532-577102B00 | Heatsinks TO-220 HORIZ/VERT SLIM CHANNEL STYLE | 1 |
604-WP7113ID | Standard LED - Through Hole HI EFF RED DIFFUSED | 1 |
581-SA105E104MAR | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 20% Z5U | 9 |
667-ELC-18B331L | Power Inductors 330UH RADIAL COIL CHOKE | 9 |
140-RXJ331M1CBK1012P | Aluminum Electrolytic Capacitors - Leaded 16V 330uF 105C 10x12.5 mm | 9 |
140-RXJ101M1HBK1016P | Aluminum Electrolytic Capacitors - Leaded 50V 100uF 105C 10x16 mm | 9 |
299-680-RC | Carbon Film Resistors 680ohms | 1 |
299-120-RC | Carbon Film Resistors 120ohms | 1 |
299-27K-RC | Carbon Film Resistors 27Kohms | 2 |
299-1K-RC | Carbon Film Resistors 1.0Kohms | 2 |
299-470-RC | Carbon Film Resistors 470ohms | 48 |
299-10K-RC | Carbon Film Resistors 10Kohms | 6 |
571-5556416-1 | Telecom & Ethernet Connectors 8 PCB TOP ENTRY | 14 |
571-7969492 | Terminal Blocks 5.08MM VERTICAL 2P wire protector | 3 |
571-5-146281-2 | Headers & Wire Housings 2 P HEADER GOLD 30u single row | 2 |
649-65474-002LF | Headers & Wire Housings SHUNT TIN | 1 |
Most of the components are overly critical and some can be omitted in certain cases. The electrolytic capacitors must only be subsituted with low-ESR versions only. Failure to do so could result in instability in the regulation circuit. If you are using a well regulated 5vdc supply, you will not need the voltage regulator or its heat sink. This will require a jumper to be placed across the +5vdc bypass terminal block which effectively shunts DC IN 1 directly to the board logic.
Building the Ren48LSD
- Install the 1N5819 diodes near the voltage regulator – note the correct orientation
- Some find it easier to install the two decoupling capacitors near the RS485 chips at this point - jump ahead one picture to see where they go - otherwise install them after the sockets
- Install the nine decoupling capacitors near the IC sockets and oscillator
Note that if you are using a regulated 5vdc power supply for your input, you can omit installing most of the regulator circuitry.
- Install the two 2-pin shunt jumpers (note picture shows only one installed)
- Install the +5vdc bypass block (OPTIONAL for non-5vdc input) – note correct orientation
- Install the LM2575 regulator (OPTIONAL for 5vdc input) - note correct orientation
- Install the 100uF/50v capacitor (OPTIONAL for 5vdc input) – note correct orientation
- Install the 330uF/16v capacitor – note correct orientation
- Install the choke coil (OPTIONAL for 5vdc input)
- If you are not using the 5v regulator then you need to install a jumper across the input/output of where the regulator goes. A 1/2W resistor lead is good for this but any 18-20 gauge wire is fine.
- Install the fourteen RJ45 jacks – note that side-entry jacks can be subsituted
- Mount the 5v regulator heat sink if you installed the regulator – use a small amount of heat sink compound
Initial Testing
Connect your power supply to the “DC IN 1” - it supplies power to controller portion of the board as well as strip outputs 1-6. “DC IN 2” is a separate input to drive strips 7-12. Note that the ground is shared between the two inputs. If you are using a well regulated power supply as your power input, the regulator circuit should not be installed. However, you must manually bypass this by placing a jumper wire between the +5vdc bypass terminal block. Turn on the supply and verify the power LED lights up. Verify you have 5v between pins 1 and 14 on each PIC socket as well as between pins 5 and 8 on the 485 chips.
Renard Protocol
Make the following changes:
Renard-DMX Protocol
#define DMX_START_ADDRESS 1
Final Testing
- Common +DC
- Red Ground
- Common +DC
- Blue Ground
- Common +DC
- Green Ground
- Common +DC
- White Ground
Q1: What if I only have 6 strips?
Here is the schematic drawing for the Ren48LSD in PDF format (NEEDS UPDATE FOR V3C) - File:Ren48LSD-Schematic.pdf
