Renard Data Cables
Revision as of 14:36, 15 February 2011 by Ravinglunatic (talk | contribs) (Created page with ''''The data cables shown on this page apply to the current Renard board designs at DIYC. Some earlier designs/prototypes may have different cable requirements, when in doubt che…')
The data cables shown on this page apply to the current Renard board designs at DIYC. Some earlier designs/prototypes may have different cable requirements, when in doubt check the dedicated wiki page for that particular board.
Directly to computer COMM port (RS232 connection)
Mainly for Renard 64XC and Renard SS boards
  PC DE9 Pin 3 to Renard DE9 Pin 3
  PC DE9 Pin 5 to Renard DE9 Pin 5
PC DE9 Pin 3 to RJ45-pin 4
Using a RS232->RS485 or USB->RS485 converter
Due to the many different types of RS232->RS485 and USB->RS485 converters available, the drawing only refers to the signals coming from the converter. Check the documentation for your converter to figure out how/where to hook up the correct wires.
In a DMX environment
DMX using XLR Connectors
Connecting multiple Renard boards
Generally only a regular straight-thru CAT5 cable is required to connect a Renard board to other Renard boards.
