SSRneon
![Version G2](/wiki/images/d/d1/SSRneon_G2_PCB.jpg)
Safety Features
![ne-2E](/wiki/images/9/97/Ne-2e_picture.jpg)
![Neon glow.jpg](/wiki/images/f/f1/Neon_glow.jpg)
1. Dual Neon bulbs that indicated the presence of AC Voltage !
![terminal block](/wiki/images/8/86/Terminal_block.jpg)
![TA-200](/wiki/images/7/7f/TA-200.jpg)
Order your own boards
Home Etch
![copper](/wiki/images/9/9c/SSRneon-G2_wiki_etch.jpg)
Fuse Rating
![fuse](/wiki/images/2/25/Fuse.jpg)
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Bowf, SSRoz, SSRez.
BOM for 120VAC Operation:
QTY Mouser #: Description 2 606-A9A Neon Lamp 65VAC .7mA NE-2E 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED 5 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 & R11 4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 & R8 2 660-CF1/4C104J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10, 4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional, but worth every penny) also marked U1, U2, U3 and U4 5 571-2828372 Terminal Blocks 5.08MM PCB MOUNT 2P Note regarding resistors. You usually want to purchase resistors from Mouser in quantities of 100 of a specific value. You usually can get 100 resistors for the same price of 20 individual resistors. (You will eventually use them !) As noted above in the FUSE Section, you have a choice to make. You only need one fuse per SSRneon. You should always order extra fuses. 1 504-GMC-2 5mm x 20mm Medium Time Delay Fuses 125VAC 2A Med Time Delay 1 504-GMC-3 5mm x 20mm Medium Time Delay Fuses 125VAC 3A Med Time Delay 1 504-GMC-4 5mm x 20mm Medium Time Delay Fuses 125VAC 4A Med Time Delay 1 504-GMC-5 5mm x 20mm Medium Time Delay Fuses 125VAC 5A Med Time Delay 1 504-GMC-6 5mm x 20mm Medium Time Delay Fuses 125VAC 6A Med Time Delay 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay The following items are NOT available from Mouser. You can get everything but the TA-200 from your local hardware store or home center. See above for TA-200 sources. 2 Screw,#8x1/2" Pan Head Sheet Metal (You can use the screws that come with the TA-200 if you cut them down) 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 8A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum The power cords are often fashioned from standard household extension cords with one of the ends cut off. You can also make your own with SPT wire and 'vampire' plugs/receptacles.
240VAC Operation
FireGod
Here is a picture of a completed SSRneon:
![Version G2](/wiki/images/0/08/SSRneon_G2_BUILT.jpg)
This PCB has a different terminal block --> for the AC input line then what is shown in the BOM. This is simply a personal preference.
Wiring The SSRneon
The following image shows how to connect wires to the SSRneon.
If all is well, you should see both neon bulbs glowing signaling AC voltage is present and flowing through the fuse. The LED should also be lit to indicate that 5 volts DC is being supplied by the lighting controller.
![Version G2](/wiki/images/1/14/Ssrneon_001.jpg)
Original SSRneon
