RGB Lighting
RGB vs Pixels
Great information to review if you are just getting into RGB Lights. Will help you try to decide how and which direction you would like to go with RGB lights. There are alot of great options from the budget minded to over the top.
What is a Pixel or a Strip Good information talking about the terminology.
Dumb RGB or Intelligent Pixels?? Great comparison of what both are.
Things You Will Need To Start Using Dumb RGB
"Dumb" RGB Lights
Dumb RGB lights are any RGB LED that cannot be individually controlled. This mean you can use a DCssr, REN48LSD, or any other DC Controller to control the lights. You can control a whole string or strip with 3 channels instead of each led being 3 channels like the intelligent. More information will come as i get it compiled.
Wall Washers
Used under overhangs, or any where you would like RGB light spread over a large area. There are many types and varieties out there to all allow you to do this. Some can be bought assembled, some are DIY. Here is the List.
RGB Strings
RGB Strip
Other
Intelligent Pixels
Here is a list of what are considered intelligent pixels and some places you can pick them up. There are alot of places you can get them and the prices vary. To use these types of pixels you will need some sort of a controller to make them work. When choosing your controller make sure it will work with the protocol type of pixel you are using.
Here are the controllers that work with either RGB or Pixel lights. They range from Renard, DMX, SPI, E1.31, Etc. Find what suits yours needs.
For full list of Controllers
Power
Everything you will need to power up your lights
Wiring
Information about different wiring of RGB and Pixels
