SSRneon-G2-LED
![Version G2](/wiki/images/e/ec/Ssrneon_pcb.jpg)
The current Versions of the SSRneon are SSRneon-G2 and SSRneon-G12-LED.
Safety Features
![ne-2E](/wiki/images/9/97/Ne-2e_picture.jpg)
![Neon glow.jpg](/wiki/images/f/f1/Neon_glow.jpg)
![small](/wiki/images/e/e7/SSRneon_G2_LED_smaller.jpg)
The SSRneon-G2-LED has two key features not present in the SSRneon-G2:
1. The 2 ounce copper AC traces are mirrored on both sides of the board. This allows for greater current carrying capacity. (8 amps)
2. There are LED channel indicators. These LEDs will flash and dim in the same manner as the lights that are hooked to the SSR.
![terminal block](/wiki/images/8/86/Terminal_block.jpg)
![TA-200](/wiki/images/7/7f/TA-200.jpg)
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
![fuse](/wiki/images/2/25/Fuse.jpg)
The SSRneon-G2 has the largest combination of trace sizes and copper weight of any of the DIY SSRs to date. (6/17/2011) With that said, a Fuse of 4 amps is a good place to start. If you want to drive more then 1 amp through any individual TRIAC (channel), then you can ramp up to as high as a 8 amp fuse. However, once you move above 1 amp through any single TRIAC (channel), you should put a heat sink on the TRIAC(s). This does not mean you can run 8 amps through a single TRIAC (channel). A single TRIAC can handle 2.0 amps max. You will notice that the copper traces that connect to any one TRIAC are no where near the size of the main AC copper trace. So, just because the TRIAC you use may be rated for 3 or 4 or more amps doesn't mean the SSRneon-G2-LED can safely drive it at that amperage.
BOM for 120VAC Operation:
QTY Mouser #: Description 2 606-A9A Neon Lamp 65VAC .7mA NE-2E 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED 5 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 & R11 4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 & R8 2 660-CF1/4C104J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10, 4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional, but worth every penny) also marked U1, U2, U3 and U4 5 571-2828372 Terminal Blocks 5.08MM PCB MOUNT 2P Note regarding resistors. You usually want to purchase resistors from Mouser in quantities of 100 of a specific value. You usually can get 100 resistors for the same price of 20 individual resistors. (You will eventually use them !) As noted above in the FUSE Section, you have a choice to make. You only need one fuse per SSRneon. You should always order extra fuses. 1 504-GMC-2 5mm x 20mm Medium Time Delay Fuses 125VAC 2A Med Time Delay 1 504-GMC-3 5mm x 20mm Medium Time Delay Fuses 125VAC 3A Med Time Delay 1 504-GMC-4 5mm x 20mm Medium Time Delay Fuses 125VAC 4A Med Time Delay 1 504-GMC-5 5mm x 20mm Medium Time Delay Fuses 125VAC 5A Med Time Delay 1 504-GMC-6 5mm x 20mm Medium Time Delay Fuses 125VAC 6A Med Time Delay 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay The following items are NOT available from Mouser. You can get everything but the TA-200 from your local hardware store or home center. See above for TA-200 sources. 2 Screw,#8x1/2" Pan Head Sheet Metal (You can use the screws that come with the TA-200 if you cut them down) 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 8A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum The power cords are often fashioned from standard household extension cords with one of the ends cut off. You can also make your own with SPT wire and 'vampire' plugs/receptacles.
240VAC Operation
FireGod
![Version G2](/wiki/images/0/08/SSRneon_G2_BUILT.jpg)
