SSRneon-G2-LED
Version G2
Version G2
The current Versions of the SSRneon are SSRneon-G2 and SSRneon-G12-LED.
Safety Features
ne-2E
ne-2E
Three key points are what differentiates the SSRneon-G2-LED from the other available SSRs.
1. Dual Neon bulbs that indicate the presence of AC Voltage !
small
small
3. Individual LED channel activity LEDs. The SSRneon-G2-LED has two key features not present in the SSRneon-G2:
terminal block
terminal block
heat sink
heat sink
TA-200
TA-200
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
fuse
fuse
The SSRneon-G2 has the largest combination of trace sizes and copper weight of any of the DIY SSRs to date. (6/17/2011) With that said, a Fuse of 4 amps is a good place to start. If you want to drive more then 1 amp through any individual TRIAC (channel), then you can ramp up to as high as a 8 amp fuse. However, once you move above 1 amp through any single TRIAC (channel), you should put a heat sink on the TRIAC(s). This does not mean you can run 8 amps through a single TRIAC (channel). A single TRIAC can handle 2.0 amps max. You will notice that the copper traces that connect to any one TRIAC are no where near the size of the main AC copper trace. So, just because the TRIAC you use may be rated for 3 or 4 or more amps doesn't mean the SSRneon-G2-LED can safely drive it at that amperage.
USE the SSRneon-G2-LED at Your Own Risk !
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
Version G2
Version G2
