Enclosures
Enclosures
THIS PAGE IS UNDER CONSTRUCTION AND HAS NOT BEEN CHECKED FOR ERRORS!!!
Popular Enclosures
TA-200 (Terminal Access TA-200 Terminal Enclosure)
TA-200 Ukewarrior SSRez g2ktcf SSRNeon Ukewarrior DCSSR dlovely
Common usage: SSRez ACSSR, SSRNeon ACSSR, DCSSR Version 2.4
External Dimensions (HxWxD): 3.13” x 3.63” x 2.5” (7.95cm x 9.22cm x 6.35cm)
Internal Dimensions:
Datasheet
Internal Drawing
CG-500 (CableGuard 500 Coax Demarcation Enclosure)
Simple Renard 32 Combo OregonLights RPM E1.31 DMX Bridge jklingert REN48LSD jklingert
Common usage: Simple Renard 32 Combo, Simple Renard 32 RGB+W DC Controller, RPM E1.31 To DMX Bridge
External Dimensions (HxWxD): 6.5" x 8.0" x 2.75" (16.5cm x 20.3cm x 7.0cm)
Datasheet
Internal Drawing
CG-1000 (CableGuard 1000 Coax Demarcation Enclosure
E681 + Power Supply tjetzer REN64 g2ktcf SS16 WayneJ SS8 WayneJ REN24HC jrd
Common usage: Renard SS8 AC Controller, Renard SS16 AC Controller, Ren24HC AC Controller, Renard 48LSD DC Controller, Ren64 Controller
External Dimensions (HxWxD): 9.00" x 9.00" x 3.00" (22.80cm x 22.80cm x 7.60cm)
Datasheet
Internal Drawing
CG-1500 (CableGuard 1500 Coax Demarcation Enclosure)
REN48LSD + Power Supply Mangrove REN48LSD + Power Supply OregonLights PC Power Supply jklingert
Common usage: Similar to CG-1000, but box is larger. E680, E681, E682 Pixel Controllers, Various Power Supplies
External Dimensions (HxWxD): 12.25" x 12" x 5.25" (31.10cm x 30.50cm x 13.30cm)
Datasheet
Internal Drawing
CG-2000 (CableGuard 2000 Coax Demarcation Enclosure)
Renard SS24 rjchu Renard SS24 waynej Ren64 JEEPGUY
Common usage: Renard SS 24
External Dimensions (HxWxD): 13.0" x 9.0" x 3.0" (33.00cm x 22.80cm x 7.60cm)
Datasheet
Internal Drawing
Mounting Options
BillinSoFl somtng4u2c Mangrove
Mounting Threads
Mounting Enclosures Thread
Mounting Options Thread
More Mounting Options
Vendors
DIY LED Express
WLC Ventures
Alternate Enclosures
Alternate Enclosure Wiki
SS24 in 5" Fence Post
Dripbox 330 Outdoor Waterproof/Weatherproof Box- Black
Orbit Outdoor Timer Box
Plastic Food Containers
Ammo Can
PVC Pipe
Mission Control!
Threads
Painting Enclosures
Adding Vents
Sealing to prevent Leakage
Rope Caulk
Heater in an Enclosure for cold weather
Bags over enclosures to keep dry
