HLS
Revision as of 16:48, 4 October 2012 by Materdaddy (talk | contribs)
WORK IN PROGRESS
Information
History
Description
Features
Installation
All installations begin with visiting the current website and downloading the latest ZIP file: [1].
Windows
XP
1. Download HLS From website:
HLS Website
Download File
2. Extract HLS Zip file:
Extract
3. Run your new HLS executable by double clicking the "HLS.exe" file:
Run
Vista/7
TODO: Somebody with Vista/Win7, please fill in this section with pictures/steps.
Linux
HLS runs under wine. To install, simply extract the zip file and run the HLS.exe with wine:
unzip HLS_Install_6E.zip -d /path/to/HLS
wine /path/to/HLS/HLS.exe
Things tested under wine on a Debian 6.0 "Squeeze" system:
  • Audio Playback
  • Basic Sequencing
  • E1.31 output
  • Display Preview (without images, only drawing channel vectors)
  • Custom effects
  • Saving/Loading effects to libraries
  • Saving/Loading channel layouts to libraries
  • HLS's automatic check for a new version
Not Tested under wine:
  • DMX/Renard output
  • Over effects
Note: Prior to version 6B of HLS, the audio waveform display did not work correctly in wine. Joe updated the function call from PatBlt to a vector line draw which fixed the waveform display in wine. For more information read this thread: http://doityourselfchristmas.com/forums/showthread.php?21675-HLS-amp-Linux-using-wine
Upgrading
Upon HLS launch, HLS will check the download site to see if there is a newer version available. If there is, a prompt will be shown suggesting to take you there for a download. Upgrading follows almost the same procedure as installation, only you will extract the files of the ZIP on top of the existing installation.
Usage
Getting Started Manual
Joe has written a manual which describes the installation/usage and contains many screen shots and great information for getting started. Note that this was written a while ago and many things have changed over the development per feature requests on DIYC so some screens may look different than in the manual. The basic concepts of channel layout, preview preparation, sequencing remain the same so the manual is still very useful, especially for a beginner to HLS. The manual can be downloaded at the main HLS download site here.
Howto Videos
Joe's Videos
  • Intro Video - This video goes over most of what you'll need to get started including selecting audio, managing channels, adding effects, setting up a preview.
  • RGB - This video shows the changes to Over Control and the addition of RGB support.
  • Beta0 - This video was from when the first beta went to testing. It covers a couple more sequence editor changes as well as setting up channels for output to Renard and E1.31.
  • Dimming Curves - Setting defaults for dimming values, dimming curves, and library support. The library support covers insertion of custom effects and saving of channel layout.
  • Converting to RGB - Converting channels to RGB. If you previously had
  • Automatic RGB Conversion - This details how to use the automatic RGB conversion tool.
  • Group Move/Resize - Demonstration of the group move and resize functionality including a cool trick for fast chases.
  • Pixel Plane - This video is a quick demonstration of how to set up a pixel plane and add an effect from nutcracker.
  • More Pixel Plane - A more in depth look at what can be done with pixel planes, multiple universe output, and a short demonstration of the manual test mode.
  • Pixel Plane Training - This is the latest video from Joe that discusses HLS channel capabilities and angus40's stress tests running HLS and pixel plane capabilities. This demonstrates using the dumb-RGB-like effects and over effects to Pixel Planes.
  • Segments Training - This video demonstrates the new segments feature using a 30 channel pixel arch.
Tips
Ctrl+click Shift for info
Keyboard Shortcuts
How do I re-order channels?
How do I delete effects?
How do I make channels actually output data?
How do I make channels NOT output?
How do I import sequences from sequencer X?
How do I convert 3 individual channels to 1 RGB channel?
How do I remove all effects from a channel?
How do I copy/paste?
How do I cancel a selection?
How do I select an effect, starting from the upper corner?
How do I make an effect bigger?
How do I move an effect?
How do I move an effect from one channel to another?
What are the keyboard shortcuts?
How does the Beat Track work? http://doityourselfchristmas.com/forums/showthread.php?20796-Beat-Track https://vimeo.com/44991162
Useful Links
