E68X-to-DMX
E68X-to-DMX Adapter
E68X-DMX Schematic
Here is the current BOM for the adapter
Board Layout
E68X-DMX Schematic
E68x Configuration
  • Pixel Type of "DMX PIXEL"
  • String Count of 1
  • Pixel Count of 170
The converter must be plugged into the first connector of the group (1-1, 2-1, 3-1 or 4-1) if you want a full universe (actually 510 channels).
You can also get creative and configure it with 4 strings of up to 42 pixels and use all four connectors in a group and you will end up with four separate DMX streams starting at addresses of 1-126, 127-252, 253-378 and 379-504. Smaller string lengths will result in smaller bundles of DMX addresses. Note that all strings sizes have to be the same length for a given group. Also remember the unit of measurement is pixels or 3-channels - not single channels.
Converter Configuration
The four jumpers must be placed all on the left for DMX wiring or all on the right for Renard wiring. You must install all four of the jumpers or install wire jumpers instead for the converter to work properly.
If you are using 5v pixel power on the connector you can jumper out the 78L05 regulator to provide 5v power. If you are using 12v pixel power then be sure to NOT have the bypass jumper installed or it will fry the RS485 chip. It is not recommended to use this board with 24v pixels as it may cause the regulator to overheat.
