Pixel Properties
Pixels come in many different shapes and properties.  The most common properties  are:
Form Factor
- 12mm pixel nodes
- Strips (Usually 5M length)
- Bare board (no waterproofing)
- Hollow Tube
- Solid Tube
- Solid Silicone
- Solid Epoxy Resin
- Modules
- Square
- Rectangular
LEDs per meter
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
LED Type
- 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
- 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
- 8mm (typically used in strings)
Waterproofing
(don't trust the IP ratings, they vary quite a bit!)    Additional information about sealing pixel strings
- Injection Molded Silicone
- Epoxy Resin coated PCB in Silicone
- Cast Epoxy Resin in Sleeve
- Cast Epoxy Resin coated PCB
- 4 bits per color, 16 dimming levels per color.  (Total Colors = 16x16x16 = 4,096 colors)
- TM1812          (can drive 12 channels, or 4 RGB LEDs)
- SM16715
- SM16716
- P9813 - 4 wire
- P9816 - 4 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
| Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link |
| Example | Example | Example | Example | Example | Example | Example |
DIYLEDEXPRESS.COM
Ray Wu
