24 Channel Renard with SSR Assembly Instructions
Layout
COOP PCB V2.5
PCB 1 TBA Renard 24-Port PCB 511-BTA08-400B 24 579-PIC16F688-I/P 3 571-7969494 1 595-SN75176BP 2 511-L7805CV 1 821-DB102G 1 571-2828376 4 271-680-RC 28 532-7136DG 1 271-180-RC 24 271-27K-RC 3 271-1K-RC 4 571-5564161 2 271-120-RC 1 859-MOC3023 24 625-1N4001-E3 1 78-1N5239B 3 838-3FD-320 1 782-H11AA1 1 520-TCF1843-X 1 140-HTRL25V1000-RC 1 140-HTRL25V10-RC 1 140-HTRL16V100-RC 1 534-3517 4 504-GMA-15 2 ** NOTE UPDATED 10/06 - I put the wrong transformer part # please contact me if you purchased any.
1/20/2007 Initial Design 3/20/2007 Revision 2 submitted to test manufacturing. 7/15/2007 Changed RJ45 to comply with current Renard standards. 7/15/2007 Added additional holes for a larger transformer. 7/15/2007 Added transformer voltage selection jumpers, will allow for 120/240v operation. 7/15/2007 Changed fuse size to 5x20mm fuse from AG3 fuse. 7/16/2007 Added option for DIP or SMT MOC2032 optos. 8/20/2007 Version 2.5 submitted to test manufacturing.
Errata for Rev 1 PCB -
1) Onboard regulator not functioning properly: needed addition of 1000uF capacator. 2) Outputs are out of order. 3) Triacs are located to close together.
Errata for Rev 2 PCB -
1) Outputs 17/18 are swapped. 2) RS485 traces swapped.
