Time Resolution
Revision as of 20:50, 25 January 2013 by Jlowe (talk | contribs) (Created page)
  • 25 msec: This provides 40 timing grid spaces for every second.
  • 50 msec: This provides 20 timing grid spaces for every second.
  • 100 msec: This provides 10 timing grid spaces for every second.
  • A higher grid resolution will result in more channels displayed on the screen at one time and more timing marks on display at one time, but the disadvantage is that the grid squares are smaller.
  • A lower grid resolution will result in larger squares which are easier to see, but the disadvantage is fewer channels and timing marks on the screen at one time.
Audio File Chapter 2: Creating a Sequence Chapter 3: Channel Management
