Advanced Channel Management
This is based on version 11V.
This portion of the manual is under heavy development.
- Left-most Gray Square: This is a selection box. You left-click in here and the square becomes green. That channel (and any others you left-click on) is selected and can be moved, deleted, or otherwise modified.
- Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware.
- Order: This field is used to adjust the order of the channels.
- Multiple DMX Group: A normal DMX universe has 512 channels. This is active when using hardware that allows 4096 channels per universe.
Advanced Renaming Channels
Reordering and Renumbering Channels
Using Folders
Deleting Channels
Program Help File
Paste help file from HLS channel manager here.
| Setting Up HLS Channels | Chapter 3: Channel Management | RGB Channels |
