Sequence Playback
This is copied from the Getting Started Manual. It is in need of heavy revision.
Playing a Sequence
How to play a sequence. Buttons and shortcuts.
Adjusting Playback Speed
Speed adjustments and why to use them. Remember that you can change the play speed to ¼, ½, ¾ or full speed under the WAV file tab.
Play from a Mark
It is possible to choose a different start point to start to play from. Figure 1-75 shows an example. To select a new start point for play, right click your mouse on the timeline where you would like to start playing. A Red mark will appear in the timeline (see Figure 1-76). Next you have to click on the Play From Mark button to sat form that point.
