Creating Basic Effects
Under Development.
Based on Version 11V.
The Window and it's components
The Toolbar and relevant buttons
Selection Mode in HLS
Basic Method to Create a Selection Box:
 - All of the cells you have chosen will be surrounded by a dotted line. (See Figure 4-X).
Basic Effects
Level
Ramp Up
Ramp Down
Modifying Effects
Moving/Stretching Effects
Deleting Effects
Copy/Paste Effects
Modify Effect Attributes
