The PixelPlane Editor: MegaTree
Revision as of 02:06, 6 February 2013 by Jlowe (talk | contribs) (Meteor)
Still to document:
Text hiding for channels
Horizontal Text
Vertical Text
Current as of Version 12H.
Spiral
Figure 6-12
A Spiral effect creates the look of a spiral of lights twisting around the tree.
The Options to customize the Spiral Effect:
  • Rotate Clockwise: change rotation direction.
  • Speed of Rotation: How fast should the spirals rotate (lower numbers mean faster).
  • Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
  • Width of Bars: How wide the bars should be.
  • Spiral Spacing: How much space should there be between each spiral.
  • Sparkle: Add random sparkling pixels to the effect.
Vertical Bars
Figure 6-13
A Vertical Bar effect creates vertical bars that rotate around the tree.
  • Speed of Rotation: How fast should the bars rotate (lower numbers mean faster).
  • Number of Bars: The number of bars to rotate vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
Figure 6-14
A Horizontal Bar effect creates horizontal bars that rotate up or down the tree.
  • Motion Down: Move bars down instead of up.
  • Speed of Rotation: How fast should the bars move up/down (lower numbers mean faster).
  • Width of Bars: How wide the bars should be. This will also determine the number of bars that appear on the object.
Snow
Figure 6-15
A Snow effect creates random "snowing" pixels that float down the tree.
  • Speed of Rotation: How fast should the snow fall (lower numbers mean faster).
  • Snow Density: How dense the snowfall should be.
  • Accumulate Snow: As snow falls, have it accumulate at the bottom of the tree.
  • Snow White: Sets all accumulated snow as white, no matter what color it was when falling.
Meteor
Figure 6-16
A Meteor effect creates random meteors that streak down the tree.
  • Speed of Rotation: How fast should the meteors fall (lower numbers mean faster).
  • Tail Length: Length of the tail on the meteor.
  • Meteor Density: How dense the "meteor field" should be.
  • Sparkle: Add random sparkling pixels to the head of the meteor. Only the head will sparkle.
Fireworks
Figure 6-17
A Firework effect creates fireworks that streak down the tree.
  • Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
  • Tail Length: Length of the tail of the firework.
  • Fireworks: Firework density.
Text Considerations
To be developed. See video 2, @ 1:30 mark.
Horizontal Text
Figure 6-18
A Horizontal Text effect displays horizontal text that moves across the tree.
Options to Customize a Horizontal Text Effect:
Vertical Text
File:HLS PixelPlaneEditor MegaTree VerticalText.png
Figure 6-19
A Vertical Text effect displays Vertical text that moves up/down the tree.
Options to Customize a Vertical Text Effect:
The PixelPlane Editor Chapter 6: The PixelPlane Using Nutcracker with a PixelPlane
