The PixelPlane Editor: MegaTree
Revision as of 02:09, 6 February 2013 by Jlowe (talk | contribs) (Fireworks)
Still to document:
Text hiding for channels
Horizontal Text
Vertical Text
Current as of Version 12H.
Spiral
Figure 6-12
A Spiral effect creates the look of a spiral of lights twisting around the tree.
The Options to customize the Spiral Effect:
  • Rotate Clockwise: change rotation direction.
  • Speed of Rotation: How fast should the spirals rotate (lower numbers mean faster).
  • Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
  • Width of Bars: How wide the bars should be.
  • Spiral Spacing: How much space should there be between each spiral.
  • Sparkle: Add random sparkling pixels to the effect.
Vertical Bars
Figure 6-13
A Vertical Bar effect creates vertical bars that rotate around the tree.
  • Speed of Rotation: How fast should the bars rotate (lower numbers mean faster).
  • Number of Bars: The number of bars to rotate vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
Figure 6-14
A Horizontal Bar effect creates horizontal bars that rotate up or down the tree.
  • Motion Down: Move bars down instead of up.
  • Speed of Rotation: How fast should the bars move up/down (lower numbers mean faster).
  • Width of Bars: How wide the bars should be. This will also determine the number of bars that appear on the object.
Snow
Figure 6-15
A Snow effect creates random "snowing" pixels that float down the tree.
  • Speed of Rotation: How fast should the snow fall (lower numbers mean faster).
  • Snow Density: How dense the snowfall should be.
  • Accumulate Snow: As snow falls, have it accumulate at the bottom of the tree.
  • Snow White: Sets all accumulated snow as white, no matter what color it was when falling.
Meteor
Figure 6-16
A Meteor effect creates random meteors that streak down the tree.
  • Speed of Rotation: How fast should the meteors fall (lower numbers mean faster).
  • Tail Length: Length of the tail on the meteor.
  • Meteor Density: How dense the "meteor field" should be.
  • Sparkle: Add random sparkling pixels to the head of the meteor. Only the head will sparkle.
Fireworks
Figure 6-17
A Firework effect creates fireworks that streak down the tree. These are exactly the same as meteors, except when sparkle is applied. When it is applied, it will randomly "explode" the firework.
  • Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
  • Tail Length: Length of the tail of the firework.
  • Fireworks: Firework density.
  • Sparkle: Add random sparkling to the head of the firework. Unlike Meteor, Fireworks sparkles "explode" the head of the meteor.
Text Considerations
To be developed. See video 2, @ 1:30 mark.
Horizontal Text
Figure 6-18
A Horizontal Text effect displays horizontal text that moves across the tree.
Options to Customize a Horizontal Text Effect:
Vertical Text
File:HLS PixelPlaneEditor MegaTree VerticalText.png
Figure 6-19
A Vertical Text effect displays Vertical text that moves up/down the tree.
Options to Customize a Vertical Text Effect:
The PixelPlane Editor Chapter 6: The PixelPlane Using Nutcracker with a PixelPlane
