The PixelPlane Editor: MegaTree
Revision as of 15:01, 8 February 2013 by Jlowe (talk | contribs) (Snow)
Current as of Version 12K.
Spiral
Figure 6-20
A Spiral effect creates the look of a spiral of lights twisting around the tree.
The Options to customize the Spiral Effect:
  • Rotate Clockwise: change rotation direction.
  • Speed of Rotation: How fast should the spirals rotate (lower numbers mean faster).
  • Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
  • Width of Bars: How wide the bars should be.
  • Spiral Spacing: How much space should there be between each spiral.
  • Sparkle: Add random sparkling pixels to the effect.
Vertical Bars
Figure 6-21
A Vertical Bar effect creates vertical bars that rotate around the tree.
  • Speed of Rotation: How fast should the bars rotate (lower numbers mean faster).
  • Number of Bars: The number of bars to rotate vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
Figure 6-22
A Horizontal Bar effect creates horizontal bars that rotate up or down the tree.
  • Motion Down: Move bars down instead of up.
  • Speed of Rotation: How fast should the bars move up/down (lower numbers mean faster).
  • Width of Bars: How wide the bars should be. This will also determine the number of bars that appear on the object.
Snow
Figure 6-23
A Snow effect creates random "snowing" randomly-colored pixels that float down the tree.
  • Speed of Rotation: How fast should the snow fall (lower numbers mean faster).
  • Snow Density: How dense the snowfall should be.
  • Accumulate Snow: As snow falls, have it accumulate at the bottom of the tree.
  • Snow White: Sets all accumulated snow as white, no matter what color it was when falling.
  • Tip: The higher the "sparkle" value, the whiter the snow. For all white snow, turn up sparkle very high.
Meteor
Figure 6-24
A Meteor effect creates random meteors that streak down the tree.
  • Speed of Rotation: How fast should the meteors fall (lower numbers mean faster).
  • Tail Length: Length of the tail on the meteor.
  • Meteor Density: How dense the "meteor field" should be.
  • Sparkle: Add random sparkling pixels to the head of the meteor. Only the head will sparkle.
Fireworks
Figure 6-25
A Firework effect creates fireworks that streak down the tree. These are exactly the same as meteors, except when sparkle is applied. When it is applied, it will randomly "explode" the firework.
  • Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
  • Tail Length: Length of the tail of the firework.
  • Fireworks: Firework density.
  • Sparkle: Add random sparkling to the head of the firework. Unlike Meteor, Fireworks sparkles "explode" the head of the meteor.
Horizontal/Vertical Text
Figure 6-26
A Horizontal or Vertical text effect displays text that moves across the tree either horizontally or vertically.
  • Click Line 1 to enter text to display.
  • Click Line 2 if you wish to enter a second line of text.
  • Click Font to assign a font and size to the text display.
  • Inject at String Position: This sets the first string for the text to begin drawing on.
  • Pixel Gap between lines: This sets the amount of "dead pixels" between the two lines of text.
  • Number Pixels Wait to Begin Again: Amount of "dead pixels" to scroll before the text appears again.
  • Speed of rotation: How fast the text will rotate on the tree.
  • Injection Height: This sets the height of where the text will display.
  • Snow Density: This controls the amount of snow to appear with your text.
  • Sparkle: This adds a sparkle effect to the text.
  • Add background color 6 to text: This will add the 6th color as background behind the text. The intensity field controls how bright that color is displayed.
  • Note: You must click the Generate Text button before it will display in the animation window.
Hide Text Strings:
  • This allows you to turn off the strings on the backside of the tree for text generation.
  • Click the button and then check which channels are on the back of the tree. That will keep the text only showing on the front strings.
The PixelPlane Editor Chapter 6: The PixelPlane Using Nutcracker with a PixelPlane
