Upgrading HLS
Revision as of 02:37, 22 February 2013 by Jlowe (talk | contribs)
Standard Upgrade
  • Simply download the latest version, unzip the files, and overwrite the old files with the new ones.
Upgrade Path for Skipped Updates
  • Upgrading from a version less than 11E: Install version 11H [1]
  • Next, upgrade from 11H to the most current version. [2]
Download and Installation Chapter 1: Getting HLS Chapter 2: Creating a Sequence
