Strawberry
Member
I've assembled a couple "16_Expansion_SMD" boards from Scott Hanson's design when testing using the BBB_16_Expansion I noticed the lights flickering in test mode. it resembles a loose/no ground for the pixel data. I assembled 2 boards which have the same characteristics and have also tested on a F16V3 with the same flicker.
Any Ideas?
Comparing the through hole VS smd design the only difference is R3 is 330 ohm.
Any Ideas?
