Allan Renard settings
First you need a Serial poutput from computer to your Renard. Typically it is RS485 protocol, + - and Grd, but many RS485 do not have GRD so you just use + & -
In Vixen, add your Renard controller – or SKIP if done……
Name it
Set the number of outputs.
You should see your Renard controller. Patch as a single output per channel
Renards have data on pins 4 (data-) & 5(data+) with GND on pins 1 & 2. I use CAT5 cable to connect from RS485 dongle to Renard RJ45 port.
Hope This Helps
Name it
Hope This Helps
