I forgot that I did a comparison of strips and strings in arches.
Here's a short video.
Left to right.
- Strip
- String inside
- String drilled through the side
I guess I decided last year that I like the side view best.
Nothing fancy needed. Just drive some rebar stakes into the ground at an angle leaving about 6" exposed and then slip the tube over it. If you don't like the shadow the rebar makes, then leave it on the outside of the tube and zip tie it together.If I knew how to build the base of a 2", I would probably try it and put the 2" in the back row; 1" in the front row. I just don't know how.
I actually stopped doing this a few years ago in favor of a slightly fancier method. But when i did it, I angled the rebar so that it holds the tube without allowing movement. A slightly different angle than the the angle of the tube. So that it binds somewhat.Are you drilling a hole and letting the LED out before it runs into the rebar? I didn't want the wind whipping the rebar into the LED.
No. The pigtails come out the ends of the tube.
So you did.
