focusedonsound
New member
After this years trials and tribulations with my make shift Mega tree, I have decided I will be adding a permanent flag pole where my Mega tree will reside.
So this leads to my question I want to build the ultimate flag pole which will be "Mega tree" Ready.
I had planned to build this new flag pole approximately 20' tall a little under or over is fine.
My current construction list would be as follows. (AND YES this may be over kill)
1 - 12" x 48" concrete base.
2 - Pole 1 = 10' x 2" Galvanized steel pipe.
3 - 2" to 1 1/2" reducer
4 - Pole 2 = 10' x 1 1/2" Galvanized steel pipe.
5 - 1 1/2 to 1" galvanized reducer
6 - 5' x 1" Galvanized steep pipe.
6 - 2 pulleys
7 - cleat
8 - Rope - 7mm power rope capable of handling 2200lb working load.
This should give me a 21' Flag pole with 4' of the pole in the ground.
My reason for 2 pulleys rather than 1 is so I can raise and lower my lights more evenly as well as having more stability for ring which my lights will hang from.
My only thought at this point is the Tree topper, and how to easily get my Star to the top of the tree. At first thought I was thinking to maybe put a rope inside of the flag pole and run it up to a cap. I would then be able to some how pop the cap off with a long pole lower it down and replace the cap with my topper and raise it back into place with minimal effort from the ground.
I am also thinking that it would be great to be able to use this same pole for my Antenna maybe?
Lastly any other suggestions before I get started on this project would be much appreciated
Thanks,
-Nick
6 - 2 pulleys
7 - cleat
Thanks,
-Nick
