Cannot assign audio to sequence
jwilliams31
New member
I'm running Vixen 2.1.1.0 on Windows 10. The sequence file shows audio assigned, but when I run it, the audio doesn't play. If I go into Audio, it shows nothing is assigned to it. When I try to assign audio, I can select the mp3, but then nothing happens. It still says there is no audio assigned to the sequence.
This is the first time in many years that I've seen this.
The only thing that has changed since last time is Windows 10. Previously I was running on Windows XP (on a very old laptop). Could there be some weird security setting on Windows 10 that won't let me assign audio? I tried running Vixen as an admin, but it still didn't work.
Or is this just some kind of weird bug I've suddenly discovered.
Any tips would be appreciated.
I don't think I have run 2.1.1.0 on windows 10 but it sounds a bit like a audio out selection problem. Do you have multiple audio outputs on your computer?
Back
Top
