RichieNorthcott
Member
The fact there are three cables suggests it is DMX (i.e. separate Power, DMX in, DMX out). From the product description:
Signal Input: differential input (3XLR: A, B, GND) Well they aren't XLR but they are 3 pin. I don't think you can damage by trying different combinations of A/B/ground until it works, but don't hold me to that!.
Signaling protocols: standard DMX512 protocol (1990);
Operation Modes:
Series connection: Writable address code This is the programmer which is available. If you haven't requested anything specific then it probably has its start channel set to 1.
maximum 170 pcs lamps connected one universe of DMX
This is why it's always worth buying a sample
If you wanted to pop the unit open and if it's possible to photograph the electronics inside, that would also help confirm!
To connect you could get an XLR male and swap it out for the supplied connectors. You would need to consider waterproofing etc though. To test temporarily you should be able to poke wires into the holes on the small 'DMX' connector.
Afterhought - if you have a test meter, you should be able to get continuity between the Power connection ground and one of the pins on the 3 pin 'DMX' connector. That will tell you which ground is. Then the other two pins are either A/B or B/A.
Operation Modes:
