I seem to be having some issues compiling the Renard firmware in MPLAB X. I downloaded the latest version and received errors that p16f688 was not found. From what I gather, the latest versions seem to use different settings.
I'm assuming I'm missing something, do I have to download a different compiler than the one that comes with XC8? I can get the exact errors if needed but I uninstalled it to try and older version.
When I tried MPLAB 8.92 I get the following errors.
Debug build of project `C:\temp\renbuild\renbuild.mcp' started.
Language tool versions: MPASMWIN.exe v5.51, mplink.exe v4.49, mplib.exe v4.49
Preprocessor symbol `__DEBUG' is defined.
Mon Dec 18 22:00:33 2023
Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F688 "Renard_1825_20130626_1372291520.asm" /l"Renard_1825_20130626_1372291520.lst" /e"Renard_1825_20130626_1372291520.err" /o"Renard_1825_20130626_1372291520.o" /d__DEBUG=1
Warning[202] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 459 : Argument out of range. Least significant bits used.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 493 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 493 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 495 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 495 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 498 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 498 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 518 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 518 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 521 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 521 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 522 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 522 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 538 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 538 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 539 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 539 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 540 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 540 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 542 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 542 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 543 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 543 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 613 : Symbol not previously defined (BANK1)
Message[302] C:\TEMP\RENBUILD\RENARD_1825_20130626_1372291520.ASM 613 : Register in operand not in bank 0. Ensure that bank bits are correct.
Debug build of project `C:\temp\renbuild\renbuild.mcp' failed.
Mon Dec 18 22:00:34 2023
BUILD FAILED
I am running Windows 11. I don't think that should make a difference but its good to know.
Thanks in advance for any help.
BUILD FAILED
