Would like some input on building a new tree. HolidayCoro has their presale going on and I noticed the following:
My original plan was to buy the ready-to-run falcon f16v3 kit and purchase/build the rest of the tree on my own. I'm looking to build a roughly 10' tall tree (I know, not very mega). I guess my only concern is I know nothing about HolidayCoro's controllers. Is the controller provided with their presale something comparable to the falcon? For $660, the HolidayCoro seems like a very good deal with all that comes with it, considering just the ready-to-run falcon controller is $400.
Thanks!
The more you research in this hobby, the more folks you'll see have lots of disdain for Holiday Coro due to the owner. I, however, had a great experience with them my first year (this year), and especially with my sales rep Nathan. I bought a ready to run megatree kit from them, but I went with 12V, and also went with a 16 strip, 100 pixels per strip, 180 degree tree with 1.5" spacing. I also had an additional 16 SPI output board put on mine (for a total of 32 ports), an additional 350W Meanwell power supply, and a long range expansion board so I am ready for next year when I expand things. I would HIGHLY recommend going with the HinksPix Pro controller. Yes it's $45 extra with that kit, but it also gives you much more flexibility for expansion down the road. I'd recommend checking out the comparison page they have set up that shows you the differences:
https://www.holidaycoro.com/kb_results.asp?ID=181. I ran each strip of our tree on its own output port, so I used 16 ports for the tree itself, and another port for the Boscoyo Chromastar 23". Next year I plan on upgrading the tree to 24 strips instead of 16, and going somewhere around 200 degrees. Instead of a port for each strand, I will be running 12 ports for the tree with two strands on each port since we only ran the tree at 20% brightness.
All that being said, we are taking our show down this weekend and the Holiday Coro stuff we have has been rock solid for the month it was up in heavy winds and rain. Worth noting that with any of their tree kits there is still a good bit you will need to buy. HC suggests using chain link fencing top rail for your tree pole. I purchased some to use for mine, but just was not comfortable with the strength of that, so I scrapped that idea and went with Walter Monkhouse's ASAP Jr pole design along with his Portable Hole design:
http://www.magicchristmas.org/asap-jr.html This setup was rock solid and I'm glad I went with it instead. For all the hardware and supplies needed for the ASAP Jr and Portable Hole, you will be looking at another $200-300, though, and you'll need to be handy enough to build it. Make sure you use at least 3 guy wires to stabilize the tree. I used 2 going to the front left and right, then one going straight back behind the tree to also help keep tension on the strands.
