The connecters I posted are called push in connectors. They should have them at the hardware stores. If not try Amazon. The blue connectors you posted are to be used for low voltage wiring only. Like in your cars 12v system. Do not use them to connect AC current as this could be dangerous. The way the relays work is there is a 5v side {if that's what the rating is on yours} that is the controlling side from the pi. The switching side is the high voltage side. They work kinda like your light switch. There is 110v in your home walls. Pretend you are the raspberry pi. Your brain says turn on the light. You use a low voltage energy {your hand} and flip the switch controlling the high voltage. Like a relay you are physically touching the switch but never the high voltage. The 5v and 110v are going to be somewhat in the same location but never touch.
Oh, i didn't even think about that with the connectors.. only hardware store around my town is a family owned place that never had what i need. but i bet another place i know about would have them or i will just order some online.
The lor board will be a learning curve also. But will have the heavy work done for you as far as the circuits go.
Why you say that? its already build.. just plug up the two cords, and a Ethernet cable and set the Vixen for it and turn it on should be...
your right i wont have to be building anything.
Ok, So my concerns are confirmed and it leads me to a few more questions.
1) How many power feeds are you going to have coming in to this enclosure?
2) How many Amps per feed?
3) Are you going to fuse the outlets?
4) If yes, what size fuses are you going to use?
If the SSR’s are rated at 10 Amp and you only load them to 5 Amps with 8 relays you are still looking at 40 Amps. Of course fully loaded that is 80 Amps and this is a huge problem with how you are wiring them. The daisy chained neutral is not big enough to handle anywhere near 40 Amps, much less 80 Amps. I am not sure that your Ground is even big enough in the event of a case short to Ground.
Some more detail as to what you are trying to run with this as far as electrical load would be immensely helpful in helping you build a safe and functional circuit.
Regards,
John.
1> Power feeds? only one, as main power. it have 5v from the PI then the 110 from the plug in.
2>Amps, not sure i have to test some lights and do some math
3>fuse the outlets? you mean from the outlets themselves? isnt that what the Relays do? im not sure how you would fuse those... I mean all christmas lights have fuses inside the plug in for them
4> its 10 amps per relay.. and so there are just 2 sockets on one outlet.. so you don't think you can pull 20 amps through 14 gaudge wire?
I don't get why it would be any driffrent from me plugging in (6) 100 light sets of lights into a 100 foot drop cord that is plugged into a outlet on the side of the house?
I know for a fact that Christmas lights really don't pull that many amps.. LED christmas lights even less...
I run 2 sets of 100 light Christmas lights, along with a lighted candy cane, a 2 foot Santa Claus figure off of a 200 watt power inventor on my truck every year it runs all of that just fine. I think i was at around 2 amps total. its been a while since i checked it i will be checking them again this year want to add more so might use my 400watt inventor. Are you a licensed electrician?
You should check out this guys set up.... it looks.... interesting to say the least
https://www.youtube.com/watch?v=m83UdW67hVY
