When i try to open the file in vixen;all i get is a display that says 0 channels and no sequencing there. i am using 2.1Here's my sequence that I started using last year. It's for a lot of channels, but the core (banjo and guitar) only run on a small subset of channels. It should be very easy to modify for a different setup.
Enjoy!
It plays in 2.1.0.0 & 2.1.4.0 without a problem. Make sure the *.pro goes in the 'Profiles' directory, it wont run without the profile.When i try to open the file in vixen;all i get is a display that says 0 channels and no sequencing there. i am using 2.1
ok i got it to come up and play now. Who knew you had to add that to work right, i have never had to do it. Now how do you change the controllers, where you go to usually change the plug ins, is not lit up to do so.
I have one from 2010, if interested PM me and will send you a link.
File is for LOR with 176 channels and easy to pick out the elements you want.
