I'm trying out the free version of Eagle, though haven't really used any other PCB software, either.
I'm trying to design a simple USB device charger board to put in my car. The problem I'm having is figuring out how to design the board's power input. I plan on putting the board in a small enclosure and have 2 wires come out of the box so I can connect them to the AUX power (switched with the ignition). I can't figure out how to just leave a couple pads on the schematic where I need to supply the power and ground - and then have it show up on the PCB.
I tried adding pads on the PCB and then routing manually to them, but Eagle just beeps and won't do it.
Hopefully that explained the trouble adequately.
It's the 2 pads at the bottom. One needs to connect to the diode and the other to ground, then I just solder a couple wires off the pads and then run them out the enclosure. Yes, I'll make a ground plane, but need to get this fixed first. I'm guessing it really needs to be done on the schematic, not the board.
