bcstuff
New member
I wanted to share an inexpensive element I was designing that will be created using Boscoyo pixel mounting strips, pixel nodes and non-metallic conduit.
The idea came from Matt Johnson's huge snowflakes and a project I did back in January 2013 called Easy LED Snowflake Spinners.
The wife wants to switch to all pixels for 2017 so I designed a 6' version of a spinner, star, and snowflake with pixels. I have named them Spinner StarFlakes.
The first part is 2 10' pieces of Sch 40 non-metallic conduit attached together to create a pvc circle about 237" in circumfrence which will give a diameter of about 75" or 6'3". $3.50
Then next part of the element is James's Boscoyo pixel mounting strips. I calculated about 8 strips but with waste lets say 9 or 10 to make sure there is enough. $14
The circle is divided by 6 with attachment points on the outside the ring and the center pixel hole with 2 levels of branches to make an inner and outer 6 point star.
This drawing is to scale with the appropriate amount of pixels spaced at 2".
With grouping in software, this will function as a 12 spoke spinner, a large 6 point star, a small 6 point star and a snowflake with 6 spokes for Mike (Wolfie).
Example of the nodes used for the snowflake grouping.
Total node count for this project with only 1 row of pixel nodes is 372. $112 (@ .30/node)
Grand total for this project $130 for a 6 foot pixel element.
I plan to build one and see if I like the single row of nodes. If I think it needs more I will make a parallel strip next to the current row to make it 2 pixels wide.
*** Tom (TomL8345) wrote up a how-to in the Wiki**
http://www.doityourselfchristmas.com/wiki/index.php?title=StarFlake_Spinner
