Really awesome additions. Just downloaded v7. One problem I've got is I get an Unhandled exception has occured in your application when I try to Undo the Mega tree. I also drag out the megatree to a pretty good size, but it scales it down to a little tree. Anyway to get the tree to be bigger? One other issue I get, if I use an existing profile it seems to work pretty good, but I can't seem to make a new profile, I get a exception error that Object referrence not set to an instance of an object. I don't even know what that means. Thanks for all the hard work!
ok, I opened a profile with the new UI, and put in an arch. Switched to classic view, and the arch disappeared. Using Vixen 2.1.4.0
Still can't start a new profile. When I start Profile, click on the + and type in a name "2013" I can add channels and they show up. I can add a Renard and it shows up and I can click on that plugin setup and it appears to be normal (although the renard is not hooked up I can still set the settings, but when I add adjustable preview and click PlugIn setup, I get the same error. Object reference not set to an instance of an object. Maybe I'm forgetting a step. But as it stands, I can't make a new profile, only alter an existing one. Help?
Hi:
Thanks for all your hard work on the new editor. Works great so far.
One thing that may be of interest. When using the image stamp, it has to be attached to a channel. It would be nice to be able to use it "stand-alone". I was building a lighted fence. The poles were not to be lighted, but they still had to be attached to a channel.
One other thing: Once having placed an object, it cannot be released by double clicking or escape. Some other tool must be selected to detach from that object.
Just things I have discovered. Again, thanks. It took me far less time to do a new layout than with the old adjustable preview.
By chance did you just rename the old DLL and leave it in the folder? If so, I'm wondering if that is not causing the problem. Try removing all versions of the Adjustable Preview except the one
Yea! That was it. I did a search on my computer, and had 8 different spots I had it in. Been going all helterskelter trying to get this done, along with my mega tree build, mini and medium trees, etc. Whew, now I can sleep tonight. You guys are awesome, and this is the BEST adj. preview tools! The spiral tree and mega tree options are sublime.
OK, need to back off from the caffeine for awhile. Cheers!
:biggrin: Thanks, it took FOREVER to get the calculations for the spiral tree done right. Finally had to download that spreadsheet that's floating around for the spiral tree and work backwards. I just wish I could make it look more 3d at the base, so you can see which lines are in the "back" on the mega/spiral trees...
Timon,
I think the appreciation can only really come if you have used the original Preview tool with Vixen 2.x. While it worked fine, it was very tedious to paint all of the elements in. Especially if you had a large number of channels. I had a very detailed preview I think looked pretty good, but have many many hours in it. I first created a BluePrint in Adobe Illustrator (Grey Lines) and used it as a guide to lay the Pixels down. It worked, but again very tedious and most people don't have the tools and/or skills to do that.
For me, there are two important pieces to this tool:
1. Easy drawing of Display Elements such as arches, megatree, minitrees, etc.
2. Automatic translation from Display Element to Channel Assignments. For instance, define that you want to draw an 8 Channel Arch, Draw It, and the 8 sections are automatically drawn and assigned to the correct channels.
Combine all these features with standar copy and paste features and the ability to erase like a paint program instead of Pixel by Pixel and it just makes for an excellent tool and unbelievable increase in productivity.
ky, I just got around to watching your video here (YouTube blocked at work). Very cool seeing someone besides myself actually using it! Just watching, I can see that I definently want to have multi-channel working, for hiding and showing channels, if nothing else. Moving cells as well... Another idea is to automatically show a channel that might be hidden if you start editing in it, just as inserting an Arch or Megatree. Maybe that can be a switchable setting to do that... Little things like that make or break a user experience... I want to hear them all. What I can do to make this thing easier for you to do what we do!
Oh, an keyboard shortcuts to changing tools, don't let me forget. Maybe for Beta 9...
Hi:
This error started occuring in Beta 7 after I Saved a sequence and continues in Beta 8. I have completely deleted and reloaded Vixen 2.5.0.8 and eliminated the original Adjustable Preview.dll.
The error comes up when trying to go into Adjustable Preview and will not let it continue.
I am using an iMac (27") running Windows 7 Pro under Boot Camp.
Additional Info: I deleted the Beta 8 dlls and went back to the original Adjustable Preview. This appears to be working OK, even on the sequences that were generating the error.
