I like Gary's idea a lot, but my suggestion for improvement would be to use a Y instead of a T to minimize the entry of water.
Thanks to all who are contributing to this enclosure design!
Following up on the Ground Stake enclosure I posted above, I also used 1" PVC Pipe to make bullet-style enclosures for DirkCheapSSRs for my Minitrees. 3" Piece of Pipe with a End Cap at the top. I actually hard-wired the Light strings to the SSR. I then used one of the Plugs I cutoff the strings to make an input cord.
So far, these are working great. Had a few issues working out how to get the whole SSR and wires to stay in the pipe. Once I discovered a Rubber Band worked great as a grommet and held them in place, I was good to go. So far only one faiure of a single Channel.
My minitrees now have one power cable and one SSR signal cable going to them and the enclosure hides will up in the tree. No TA-200 and Stake next to the mini trees as in previous years.
Edit: The picture shows the first one I did prior to adding the Rubber Band Grommet.
is it one DCSSR per channel? For eg: my mini trees will be 3 colors each at 100ct strings. Would that be 3 DCSSR's per tree?
My 9 year old drinks a vitamin/protein shake like Ensure everyday...
I have taken a similar approach to some others in this thread, but I have refined it some more. First, I am adding a right angle RJ-45 jack to the board and bringing all the power cables down towards that end of the board. In this configuration the SSR will no longer fit inside a piece of 1" Sched 40 PVC pipe, but still fits nicely inside a 1" Tee fitting.
For the enclosure I cut two pieces of the 1" pipe approx 1" long, one is glued in one end of the Tee to connect and glue a cap, while the second piece I fit over the power cables before I attach my vampire plugs. I also attach a 1/2" elbow to the side outlet of the Tee and a length of 1/2" pipe to slip over rebar I pound into the ground.
When I am ready to set up the SSR, I slip my Cat-5 cable through the piece of pipe on power cables, and attach it to the SSR. I then slide the SSR into my enclosure and slide the loose piece of pipe into the bottom of the Tee without glue. The friction fit of this piece holds the SSR securely in the enclosure while allowing removal for servicing or storage.
I figure I have about $1.65 invested in each one of these enclosures, and a total of less than $9.00 per completed SSR.
