I have a Belkin unit. I done the antenna mod, but was unhappy with the results. It was better, yes, but not what I need. I then removed the attenuation as described in a 'how to'. It got a little bit better, but still is not satisfactory. I think most of my problem is the landscape of my property. My house is down off a steep grade and the eves of my house are the same level as the road. I feel the only solution is a antenna that extends above the roof. I have thought of getting a Ramsey unit, but I am afraid it will suffer the same issue, which is the landscape issue.
I have been using the 'full wavelength' antenna length specs which is 124" @ 94.7. I tried the 'half wavelength which helped nothing.
I am now thinking of extending the audio cable and locating the Belkin outside under the eves of the house and run the antenna up into the air with a small piece of pvc.
Any suggestions??
Any suggestions??
