Yes, but ...I need some info from one of our experts. Can an old germanium transistor (circa 1967), such as may have been used in an auto ignition circuit, be replaced with a modern day Silicon transistor with similar specs? Thanks in advance for your input.
Yes, but ...
The bias requirements will be different and need to be modified. Silicon transistors require around .7 V between base and emitter to turn it on while germanium require around half of that - if I remember correctly.
If your old circuit used a pair of germaniums then I would recommend a pair of silicon transistors, or even mosfets - depending on the difficulty of the circuit modifications.
Is that what you are doing, modifying an old ignition system?
Ahhh.... yes CD ignition systems.One of the members of a classic car forum I belong to is working on one, and the question came up.
