Getting closer to letting HLS doing it's magic !
angus40
Supporting Member
Well building from the hip, I have learned a ton building this small tree .
There is no cookie-cutter parts here, just a rustic diy experiment :)
Still a work in progress.
Angus,
I got to ask. Why are you going with the mesh rather than a pixel strip to mount your lights?
Hi
If you look closely , you will notice the pixels are mounted in 1/2 x 1/2 welded wire . the
mesh is for a ton of 3528 rgb that I am currently adding .
What I learned is that the pixel mounting strip is to wide for the narrow top .
Plus,I like my props to be as see through as possible .
When said and done , this 6' tree will have close to 2500 leds on it :)
This was an experiment in excess :)
I have a 125m of this strip and needed an excuse to use it .
Back
Top
