So is the goal to capture/interact with the Disney ears? Or is it to create your own "headsets", but using the MSP vs PIC offerings?
(trying to understand the context)
Green is TEST and blue RST?
Is your LP listed in COM ports? Sounds like it's not, see the pic.
Also, remove batteries from your ears... well, GwtS ears. LP's Vcc is 3.6V, GwtS Vcc is 3V, so that could be a factor.
Other than protocol there is one fundamental difference. Lightman uses a carrier based system and Disney uses a IrDa based one.
Need a IrDA capture device that's small and controllable that can be taken to the park.
Attach a diode to LaunchPad, add 2 AA batteries, it's small, portable....Need a IrDA capture device that's small and controllable that can be taken to the park.
And if someone is really serious about this, I can send them fully assembled IR logger board which will include large EEPROM to store captured data. I will be at Disney Orlando in April (I believe they do have WoC show there) and I will capture those myself if no one else does it before.
From what I understand, each hat has some sort of random ID, so that they can control small groups of hats. Other than that, this thing should be pretty straight forward.
