Let me start out with what I have done:
Measurements:
Problems:
Everything that I have read so far leads me to believe that I have bad chips (or need to get allegros) and that the voltage on all of my DB25 ports are really low.
Am I on track or do you guys see an underlying problem that I haven't (been working on it too long)?
I am tearing my hair out trying to figure this out, but get lost after steps 6-8 on the data problems troubleshooting. My voltage is neither VCC or 0 all the time it is 3.73 (before diode) and does not fluctuate from VCC to 0.
Any help would be great! Thanks!
- I made a tester following John's schematic with the LEDs.
- LED comes on in all cases
- Test Sequence lights all channels from Vixen
- I am using an old PS to power my grinch ( outputting ~5.27vdc), have jumper on J1
- I am using the Olsen595 plugin in vixen 2.1.4, with 1 to 64 channels assigned to Parallel1
- I have reflowed all of the joints on the board just to be sure that I got them all good.
- Tried swapping the ICs (MBI) around and didn't seem to make a difference
- Tried an 8ft and 6inch controller cable, same result
- The only mode in BOIS is EPP+ECP which is selected
- Used a diode (1N4001) to lower the voltage coming into the grinch down to 4.42, same result
- Tried Three different computers with the same result
- Tried simple595 in vixen with same result.
- U1-U4 -> pin 1 jumped to pin 5 activates the first channel, same with 1/6,1/7, and 1/8
Measurements:
- On boot DB25 Pin 1 reads 4.98vdc, DB25 Pin 2 reads 3.68vdc, DB25 Pin 14 reads 5.23vdc
- When vixen is running test (on for 2 sec/off for two): DB25 Pin 1 reads .1vdc, DB25 Pin 2 reads 3.46vdc/.11vdc, DB25 Pin 14 reads .1-.11vdc
- Before Diode U1 pin 5 reads 3.73, U1 pin 24 reads 5.14
- After Diode U1 pin 5 reads 3.05, U1 pin 24 reads 4.42
- After Vixen runs all pins stay around .11vdc
Problems:
- A1 does not come on alone, only with ch5
- B2 activates B1, B3/B2, B4/B3, C1/B4
- C4 does not activate
- D1 activates D2, D2/D3, D3/D4, D4 nothing
- all of E1-L1 doesn't respond
- L2 turns on L1&L2
- L3-P4 nothing
