I am planning to begin using coro stars and snowflakes with pixels, probably 24 inch versions to start with. (boscoyo studios and/or holiday coro).
One concern I have is storage, needing it to be compact without damaging the coro. (Nowadays I try to plan the storage before building a prop, so I have not ordered yet).
I have bullets, but am thinking to get & use square pixels instead for a flatter and easier to store prop. Are the square pixels better for this purpose?
What's your experience with storing these kind of props?
I can imagine finding a large box (> 24" x 24") and stacking them, but I'm imagining that the wires won't stack well, twisting the pixels and maybe bending the coro or the holes?
I am imagining using a flat material (plywood? foamcore?) with holes matching the pixels holes, and placing a coro face into it perhaps from each side; the wires would stick out one each side from a flat mounting surface. Then hoist this between the garage rafters. Just a brainstorm, not sure it would work out.
How much protection from bending does the coro need? Maybe I'm overly concerned, I have not worked with this kind of coro before (10mm); the thin stuff is pretty fragile.
