RichieNorthcott
Member
I think I know the answer to this one (as I was involved in the beta testing of the intelligent fixture feature) but in Vixen is there any way of implementing fine pan/tilt control where these use two channels each? The only solution I can think of is to us the generic DMX effect to send the required values on the two values to give a more accurate position. These units also have a 'movement speed' channel, so setting the required 'endpoints' in the data the units can be made to move smoothly between the two values by selecting an appropriate speed.
1 = Pan coarse (0 -> 540 deg)
2 = Pan fine
3 = Tilt coarse (0 -> 270 deg)
5 = Tile fine
6 = Speed (0 = fastest. 255 = slowest)
Some of the units I have been testing (since returned due to other firmware issues) don't allow adjustment of the pan range on the unit's menu, so it's set at 540 degrees. With coarse tilt only then each DMX step gives about 2 degrees mocement.
For the moving head wash units I own you can limit the pan range to 180 degrees which means each DMX value step is 0.7 degrees using just the 'coarse' channel. So these work reasonably well using the coarse channels only.
2 = Pan fine
5 = Tile fine
