ISO Vixen Prop for a column
MikelMD
Member
Hi All,
While I have used a smart object Mega Tree prop in the Preview Config. However, at on point u are limited how thin to make the column, at that point it reverts back to a tree or triangle. So, does anyone have a Vixen prop to share?
You should be able to use the Megatree Smart Object. If you are having trouble making it smaller with the mouse try typing the numbers for it on the settings section.
I use this exact method for pixel poles and they look great.
Got it!!
Thank you!
You might also consider changing the top and base heights. This will make the column top and bottom "flat" if you use zero as the setting.
Back
Top
