Larry Hazeltine
New member
I plugged everything in last night and got a bunch of random flashing before even loading Vixen. Something is wrong!
My setup:
PC - USB DMX dongle - special cat5 wired to Renard - 2 Renard 24 controllers - special cat5 wired from Renard to LOR - 4 LOR controllers
The Renards work fine when plugged into the dongle - I can run a sequence on Vixen and control the lights. The problem comes when I plug in the LORs.
I don't have a 120 ohm terminator anywhere in the line and I think that is the problem. The question is where should I put it? LOR "senses" the type of network it is on (according to their website), so it doesn't just run straight DMX. I am thinking that a terminator at the end of the LOR chain won't do anything because of the way LOR handles the data in and out.
Would it work to put the terminator at the end of the Renard chain and still allow it to pass the signal to the LOR? It wouldn't be very hard to add a resistor to the special cable I made to connect the Renard to LOR.
If the terminator does what it sounds like it does, would this mean I have to change the order of my system to have LOR first? I'd really like to avoid that if possible.
My setup:
